HAL.VSM.SetL2DestHitQualFail
Description
An attempt to set the packet resolution criterion on egress block mask filter to hardware has failed. The specified return code value is provided by the low level driver which has only internal significance.
Remedy
This is an unexpected internal condition needing technical assistance. Contact technical support with the following information: - output of "show tech"
Severity
Error
Message Text
Filter hardware packet resolution matching failed on slot %slot%, unit %unit% return code %rv%
Message Parameters
Name Type
slot uInt
unit uInt
rv uInt
Applicable Platforms
